Inconsistent data from Graphite when changing timeframes to 6+ hours
    9.4.7 running in a docker on Ubuntu, and Graphite 1.1.8
    Show a movingSum of a metric for multiple nodes. I have X devices sending data and a metric and follows how many data messages each device sent. I want to sum how many messages each device has sent over the past N minutes (N could be anywhere from 5 to 30 minutes) and show how many devices have sent a number of messages above a certain threshold during those N minutes, indicating they are ‘alive’.
    alias(sum(divideSeriesLists(movingSum(removeBelowValue(my.metric, 10), “10minute”), movingSum(my.metric, 10), “10minute”))), “Kafka”)
  • What happened?
    When changing my graph’s timeframe to anything above 6 hours I see results MUCH lower than expected.
    I expected to see 20 devices, as I do when I configure the timeframe to anything 3 hours or lower, but only saw 3 devices. The value displayed in the graph changes based on the timeframe.
    To check if my overly complicated query is the problem, I tried to simply run sum(my.metric) and that has also showed different results for the different timeframes.
I’d greatly appreciate any guidance to help me configure this graph properly!
Hi all,
I’m still struggling with this issue and haven’t found an answer. Any help would be greatly appreciated!
