Grafana version: 9.5.1
When using data-links on a table or a pie-chart, I can click on a cell (or slice) and immediately follow the data-link. However, for a bar-graph, I need to click the bar, and then select the link. (i.e. 2 clicks)
Is it possible to get the same behavior as with the piechart, where clicking a bar immediately follows the data-link without needing to click twice?
