Is there a way to merge multiple Dashboards into One Master Dashboard, or combine them?
    Azure Grafana Managed 9
    Build a master Dashboard from multiple other Dashboards, basically get the charts in one place
    One way I can do it so far but is not reliable it is to move variables by hand, and then export panels and import them into the Master Dashboard
  • What happened?
    I cant find a reliable way to do Cross Dashboard Merge
    There should be an easy way to merge multiple dashboards into one, and then customize that one as I see fit.
