- What Grafana version and what operating system are you using?
Managed Grafana in Azure
I would like to build, for example five dashboards showing information about one application per dashboard. Each dashboard will have multiple panels. Then I would like to have a “rollup” to one top dashboard where I Can see the overall health of the other dashboards. If there are any red/warnings on any of the dashboards it should be reflected in the top dashboard.
Is this possible?
