Need help on the next error id: Column metric must be of type CHAR, VARCHAR, TINYTEXT, TEXT, MEDIUMTEXT, LONGTEXT. metric column name: metric type: INT but datatype is int64
Code that works correctly:
SELECT
CONCAT(“WW”,week(created_on)) as metric
Code that get the error:
SELECT
CONCAT(“WW”,week(created_on)) || “YES” as metric,
I want to use the series override, but on the drop menu does not show me the series of metric, so following this recommendation: Two Queries with different format in Grafana - #4 by danielgonzalez I face this error.
I really appreciate any help with this!
Hi Capjairgarcia,
What are you trying with ||
operator??
Link that you post is about postgres, in postgres is like Concat but no doesn’t in mysql
Thank you, Daniel!
I really appreciate all your material you published here, It is very useful. I am trying to assign an specific color to my metric, but on the Series override is not showing the metric alias.
do you need an override for all your data?
if so, you only need add /.*/
to series override.
overwise try this:
SELECT
CONCAT(“WW”,week(created_on), "YES") as metric,
value,
time
FROM test
and add /.*YES/
to series overrides
Yes that is what I looking for, thanks for your quick help on this!
