I’m new to K6. We’ve been running Artillery test scripts in a Jenkins job and I was sending custom metrics to Datadog via http.
I’d like to use K6 and send metrics to Datadog via statsd.
In my Jenkins job, I first start the datadog agent container without problems like this:
docker run -d --cgroupns host --name dd-agent --network bridge -v /var/run/docker.sock:/var/run/docker.sock:ro -v /proc/:/host/proc/:ro -v /sys/fs/cgroup/:/host/sys/fs/cgroup:ro -e ‘DD_API_KEY=someAPIKeyHere’ -p 8125:8125/udp Google Cloud console
Then I try starting the k6 container like this:
docker run --network bridge --name k6-container -v /home/jenkins/agent/workspace/psr-jobs/psr-k6:/tmp -w /tmp grafana/k6 run --out statsd -e ‘DD_DOGSTATSD_NON_LOCAL_TRAFFIC=1’ -e ‘K6_STATSD_ADDR=datadog:8125’ -e ‘K6_STATSD_ENABLE_TAGS=true’ /tmp/schedule.js
The container tries to start, I see the big K6 ascii printout:
/ __________ \ |__| _\ ____/ .io
but then I get this error and the job stops:
time=“2022-06-15T23:57:56Z” level=error msg=“Couldn’t make buffered client, lookup datadog on 169.254.20.10:53: no such host” output=statsd
time=“2022-06-15T23:57:56Z” level=error msg=“lookup datadog on 169.254.20.10:53: no such host”
I believe the 169.254.20.10 IP address is our Kubernetes address.
hi! I might be able to help! A few questions…
- Am I right in saying that you’re running k6 docker in the jx step?
- Do you know your datadog address? you’ve set the var as datadog:8125, just confirm what that is
- You’ve definitely got an agent running?
- If you keep the container running, can you go into container k6 and reach out to that ip?
Hi Chris, thanks for asking. Here’s my Jenkins code:
pod(label: 'psr-k6')
.container('docker-cmd')
.build {
checkout scm
container('docker-cmd') {
stage('start k6') {
sh 'docker version'
sh 'docker pull grafana/k6'
sh 'docker pull datadog/agent:latest'
sh 'docker run -d --cgroupns host --name dd-agent -v /var/run/docker.sock:/var/run/docker.sock:ro -v /proc/:/host/proc/:ro -v /sys/fs/cgroup/:/host/sys/fs/cgroup:ro -e DD_API_KEY=<myAPIkey gcr.io/datadoghq/agent:7'
sh 'docker run --name k6-container -v `pwd`:/tmp -w /tmp grafana/k6 run --out statsd -e K6_STATSD_ADDR=datadog:8125 -e K6_STATSD_ENABLE_TAGS=true /tmp/schedule.js'
As you can see I pull the latest docker containers for both K6 and datadog. I start the DD container first, then the K6 container.
This network stuff is not my strong suit, which is why this issue has me stumped. I don’t know what my DD address is or how to find it.
I was able to confirm that the DD agent is running.
I haven’t found a way to keep the K6 container running. It shuts down as soon as it throws the error.
Walker
Thanks! I’ve got a few ideas for you, il get back to you on those. The datadog metrics output doesn’t error the test right? That should be a WARNING.
You could now either set the test duration to be long enough to give you time to exec into the pod or provide the -l command to k6 which will hold k6 to linger. Ref: Options reference
See if that helps so you can do some pings or tests, I think the issue here is DNS-related, or container talk-related.
