I am trying to output my k6 results to datadog locally.
I have tried the following:
Start datadog
DOCKER_CONTENT_TRUST=1 \
docker run --rm -d \
--name datadog \
-v /var/run/docker.sock:/var/run/docker.sock:ro \
-v /proc/:/host/proc/:ro \
-v /sys/fs/cgroup/:/host/sys/fs/cgroup:ro \
-e DD_SITE="datadoghq.com" \
-e DD_API_KEY=<YOUR_DATADOG_API_KEY> \
-e DD_DOGSTATSD_NON_LOCAL_TRAFFIC=1 \
-p 8125:8125/udp \
datadog/agent:latest
Run k6
K6_STATSD_ENABLE_TAGS=true k6 run --out statsd <my test>.js
I have also tried while supplying K6_STATSD_ADDR with
datadog:8125
the IP from my datadog docker process using
docker inspect -f '{{range .NetworkSettings.Networks}}{{.IPAddress}}{{end}}' datadog
With all these, I get a similar error from k6 that the metrics are not going though.
ERRO[0005] Couldn't flush a batch error="write udp 192.168.1.246:49185->172.17.0.2:8125: write: connection refused" output=statsd
Any ideas would be appreciated, thanks!
Hi @kghelani
The issue seems not really related to the k6. It just tells you that couldn’t reach the address.
What I see is that you exposing the port to the host:
kghelani:
-p 8125:8125/udp
So in theory it should work with the standard k6’s K6_STATSD_ADDR
which is localhost:8125
. For sure if k6 is running on the same host machine.
If it doesn’t work with this address I’d recommend checking the documentation of the datadog/agent
to see why it could refuse the connection.
Hope that helps,
Cheers!
I encountered the same issue as @kghelani (write: connection refused" output=statsd
), and seemed to overcome it by using the container IP directly, as such:
$ docker inspect -f ‘{{range .NetworkSettings.Networks}}{{.IPAddress}}{{end}}’ dd-agent
172.17.0.2
Then:
K6_STATSD_ADDR=172.17.0.2:8125 K6_STATSD_ENABLE_TAGS=true k6 run --out statsd ./load/sample.test.js
No metrics seem to have been received by the agent, although the test seems to run successfully:
Here’s how I initialized my local DD Agent FYI:
docker run --rm -d
–name dd-agent
-e DD_SITE=“datadoghq.com ”
-e DD_API_KEY=“”
-e DD_DOGSTATSD_NON_LOCAL_TRAFFIC=true
-e NON_LOCAL_TRAFFIC=true
-p 8125:8125/udp
Any help appreciated!
rodyb
April 18, 2023, 2:52am
4
Hi @kghelani @gurgelv
hi @akankshamitrc
To run them and see them in Datadog you need to update your query.
K6_STATSD_ENABLE_TAGS=true K6_STATSD_ADDR=datadog:8125 k6 run -e ENV=staging -e PR=pr-164 --out statsd dist/sanity.spec.js
Let me know if this works for you!
Let me know if this works for you.
