K6<->Datadog Docker Container Connectivity Error
$ pwd
/home/test/
Step 1) I started the datadog docker agent with the below Linux command:
$ docker run --name datadog -e DD_LOGS_ENABLED=true -e DD_LOGS_CONFIG_CONTAINER_COLLECT_ALL=true -e
DD_LOGS_CONFIG_DOCKER_CONTAINER_USE_FILE=true -e DD_SITE=“datadoghq.com” -e DOCKER_CONTENT_TRUST=1
-e DD_API_KEY=<DD_API_KEY> -e DD_DOGSTATSD_NON_LOCAL_TRAFFIC=1 -p 8125:8125/udp datadog/agent:latest
$ docker ps
CONTAINER ID IMAGE STATUS PORTS NAMES
58afc8d90e04 datadog/agent:latest Up 21 minutes (healthy) 0.0.0.0:8125->8125/udp, :::8125->8125/udp, 8126/tcp datadog
Step 2) However I ran the sample k6 script after k6 login cloud,
$ k6 run --out statsd samplescript.js
in standalone it captured metrics properly in the default datadog dashboard and k6 run successfully.
Step3) But when I ran the docker k6 container using the below command, even after linking K6 CONTAINER with datadog/agent
it throws below error and none of the metrics are captured in datadog but K6 ran successfully.
$ docker run -i -e “K6_DATADOG_ADDR=datadog:8125” --link datadog:datadog -e K6_CLOUD_TOKEN=<K6_CLOUD_TOKEN_AFTERLOGIN>
-v /home/test/:/test -i loadimpact/k6 run --out statsd --out cloud /test/samplescript.js
time=“2021-06-29T12:29:15Z” level=warning msg=“Couldn’t send 70266 out of 1476642 metrics. Enable debug logging to see individual errors” output=statsd
time=“2021-06-29T12:29:15Z” level=error msg=“Couldn’t flush a batch” error=“write udp 127.0.0.1:53950->127.0.0.1:8125: write: connection refused” output=statsd
time=“2021-06-29T12:29:15Z” level=warning msg=“Couldn’t send 921 out of 19366 metrics. Enable debug logging to see individual errors” output=statsd
How to fix 1)the above connection refused error and 2)the location to check logs and 3)enable debugging?
Hi there,
since you’re using the statsd output, you should specify K6_STATSD_ADDR=datadog:8125 instead, which worked in my test.
That said, note that Docker’s --link option is a legacy feature that might be removed, so you’d be better off creating a separate bridge network that both containers connect to (see Networking with standalone containers | Docker Documentation), or starting both containers with a Docker Compose file where you can specify the shared network more easily.
Regarding your 2nd question, which logs do you need? You can redirect k6’s output to a file or use the run --console-output option. If you’re doing this in a container you could save this to a directory on the host with a bind mount.
And which debug information do you need? You can use the --verbose and --http-debug options.
This resolved my issue as well with New Relic.
Missing thing was setting K6_STATSD_ADDR in k6 run command.
You don’t need it when you run k6 as a direct binary but when you run it through a container, it needs this key explicitly
After I run
docker run \
  -d --restart unless-stopped \
  --name newrelic-statsd \
  -h $(hostname) \
  -e NR_ACCOUNT_ID=<NR-ACCOUNT-ID> \
  -e NR_API_KEY="<NR-INSERT-API-KEY>" \
  -p 8125:8125/udp \
  newrelic/nri-statsd:latest
In order for my k6 container to talk to this statsd I should run
K6_STATSD_ADDR=newrelic-statsd:8125 k6 run --out statsd mytest.js
Im trying to run the same but from a Github Actions pipeline, and Its not woking. Its seems that the k6 cant communicate with NR docker port or something like that. Do you have any idea how can I do it? Thanks!
Couldn't flush a batch" error="write udp 127.0.0.1:38703->127.0.0.1:8125: write: connection refused" output=statsd
