Hi all!
I would like to know if it is possible to send messages to the producer in k6 using logging with vault certificates in .pem format. I need to connect to the producer and write messages to the topic, but authorization happens with certificates. K6 can do that? If yes, then I will be grateful if anyone has an example of a connection.
Thanks.
Hi @volfagnt,
It doesn’t currently support SSL certs. Please keep an eye on this issue or help contribute to it, which is much appreciated.
The TLS support is already available, as documented in the JS API docs.
Hi! I saw that changes were added to work with certificates. Can you tell if it only accepts certificates as a file or can it work with them as a string?
A have some errors with ssl and certs in .pem format
This Errors when i try create topic:
time=“2022-06-18T16:10:31+03:00” level=error msg=“Unable to unmarshal credentials, OriginalError: %!w(*json.SyntaxError=&{invalid character ‘o’ looking for beginning of value 2})” error=“Unable to unmarshal credentials, OriginalError: %!w(*json.SyntaxError=&{invalid character ‘o’ looking for beginning of value 2})”
time=“2022-06-18T16:10:31+03:00” level=error msg=“Failed to create dialer., OriginalError: %!w(*fmt.wrapError=&{failed to dial: failed to open connection to [kafka-test-1:9093,kafka-test-2:9093,kafka-test-3:9093]:9092: dial tcp: lookup kafka-test-1:9093,kafka-test-2:9093,kafka-test-3:9093: no such host 0xc0026803c0})” error=“Failed to create dialer., OriginalError: %!w(*fmt.wrapError=&{failed to dial: failed to open connection to [kafka-test-1:9093,kafka-test-2:9093,kafka-test-3:9093]:9092: dial tcp: lookup kafka-test-1:9093,kafka-test-2:9093,kafka-test-3:9093: no such host 0xc0026803c0})”
And when I use writer:
time=“2022-06-18T16:10:31+03:00” level=error msg=“Unable to unmarshal credentials, OriginalError: %!w(*json.SyntaxError=&{invalid character ‘o’ looking for beginning of value 2})” error="Unable to unmarshal credentials, OriginalError: %!w(*json.SyntaxError=&{invalid character ‘o’ looking for beginning of value 2})"time=“2022-06-18T16:10:31+03:00” level=error msg=“Unable to unmarshal credentials, OriginalError: %!w(*json.SyntaxError=&{invalid character ‘o’ looking for beginning of value 2})” error=“Unable to unmarshal credentials, OriginalError: %!w(*json.SyntaxError=&{invalid character ‘o’ looking for beginning of value 2})”
My code example:
const saslConfig = {
algorithm: “sasl_ssl”,
// TLS config is optional
const tlsConfig = {
// Enable/disable TLS (default: false)
enableTLS: true,
// Skip TLS verification if the certificate is invalid or self-signed (default: false)
insecureSkipTLSVerify: false,
// Possible values: “TLSv1.0”, “TLSv1.1”, “TLSv1.2” (default), “TLSv1.3”
minVersion: “TLSv1.0”,
// Only needed if you have a custom or self-signed certificate and keys
clientCertPem: “./client.pem”,
clientKeyPem: “./client-key.pem”,
serverCaPem: “./ca.pem”,
const [producer, _writerError] = writer(bootstrapServers, kafkaTopic, saslConfig, tlsConfig);
function getRandomArbitrary(min, max) {
return Math.random() * (max - min) + min;
for (let index = 0; index < 1; index++) {
var nf_k6_key = new Date().toISOString().slice(0, 10);
var currentDate = new Date().toISOString().slice(0, 19).replace(‘T’, ’ ');
var itm = getRandomArbitrary(1111111,7777777);
let messages = [
key: JSON.stringify({
correlationId: nf_k6_key + index,
value: JSON.stringify({
“ITEMNO”: itm,
“SITEID”: “BLA-BLA.COM”,
“BUSPRODUCTID”: “”,
“CRMPRODUCTID”: “”,
“BUSSECTIONID”: “”,
“CRMSECTIONID”: “”,
“BODY”: {
“NAME”: " A4Tech Fstyler FB10C (fb10c matcha green NT)",
“GROUPCODE”: “PS020406”,
“EAN”: “”,
“CODE”: “www.bla-bla.com/a4tech-fb10c-” + itm
headers: {
createdatutc: currentDate,
createdby: “SRV_NAV”,
aggregatetype:“40”,
let error = produce(producer, messages);
check(error, {
"Messages are sent": (err) => err == undefined,
@volfagnt It needs filenames. Which version of xk6-kafka are you using?
I made a few fixes very recently (below), which need to be built for testing because I haven’t released that code yet, due to the current release process. Also, the latest API changes are available here.
Hi. I find fix and build version and i have new error:
level=error msg=“x509: certificate relies on legacy Common Name field, use SANs instead”
What’s wrong? In my case common name is required field.
I take certificates from vault in pem format.
@volfagnt The error is probably a security issue, and you have two options, as stated here:
- Re-sign your certificate and add
subjectAltName
. - Temporarily disable it when building xk6-kafka with xk6 by setting this environment variable
GODEBUG="x509ignoreCN=0"
git clone git@github.com:mostafa/xk6-kafka.git && cd xk6-kafka
GODEBUG="x509ignoreCN=0" xk6 build --with github.com/mostafa/xk6-kafka@latest=.
Please let me know if it worked or not.
I’m using your add-on as a local folder. And when I try to build I get an error:
./xk6 build GODEBUG=“x509ignoreCN=0” --with github.com/mostafa/xk6-kafka=“E:/some_po/k6-v0.38.3-windows/k6kafka/k6mus/main/xk6-kafka”
2022/06/20 13:09:22 [INFO] Temporary folder: C:\Users\volfg\AppData\Local\Temp\buildenv_2022-06-20-1309.426519271
2022/06/20 13:09:22 [INFO] Initializing Go module
2022/06/20 13:09:22 [INFO] exec (timeout=10s): C:\Program Files\Go\bin\go.exe mod init k6
go: creating new go.mod: module k6
2022/06/20 13:09:23 [INFO] Replace GitHub - mostafa/xk6-kafka: k6 extension to load test Apache Kafka with support for various serialization formats, SASL, TLS, compression, Schema Registry client and beyond => E:/some_po/k6-v0.38.3-windows/k6kafka/k6mus/main/xk6-kafka
2022/06/20 13:09:23 [INFO] exec (timeout=0s): C:\Program Files\Go\bin\go.exe mod edit -replace github.com/mostafa/xk6-kafka=E:/some_po/k6-v0.38.3-windows/k6kafka/k6mus/main/xk6-kafka
2022/06/20 13:09:23 [INFO] exec (timeout=0s): C:\Program Files\Go\bin\go.exe mod tidy -compat=1.17
go: warning: “all” matched no packages
2022/06/20 13:09:23 [INFO] Pinning versions
go: found GitHub - mostafa/xk6-kafka: k6 extension to load test Apache Kafka with support for various serialization formats, SASL, TLS, compression, Schema Registry client and beyond in GitHub - mostafa/xk6-kafka: k6 extension to load test Apache Kafka with support for various serialization formats, SASL, TLS, compression, Schema Registry client and beyond v0.0.0-00010101000000-000000000000
go: finding module for package GitHub - fsnotify/fsnotify: Cross-platform file system notifications for Go.
go: finding module for package gopkg.in/tomb.v1
go: found gopkg.in/tomb.v1 in gopkg.in/tomb.v1 v1.0.0-20141024135613-dd632973f1e7
go: found GitHub - fsnotify/fsnotify: Cross-platform file system notifications for Go. in GitHub - fsnotify/fsnotify: Cross-platform file system notifications for Go. v1.5.4
2022/06/20 13:09:24 [INFO] Writing main module: C:\Users\volfg\AppData\Local\Temp\buildenv_2022-06-20-1309.426519271\main.go
2022/06/20 13:09:24 [INFO] exec (timeout=0s): C:\Program Files\Go\bin\go.exe mod edit -require go.k6.io/k6@GODEBUG=x509ignoreCN=0
2022/06/20 13:09:24 [INFO] exec (timeout=0s): C:\Program Files\Go\bin\go.exe mod tidy -compat=1.17
go: errors parsing go.mod:
C:\Users\volfg\AppData\Local\Temp\buildenv_2022-06-20-1309.426519271\go.mod:31:2: require go.k6.io/k6: version “GODEBUG=x509ignoreCN=0” invalid: unknown revision GODEBUG=x509ignoreCN=0
2022/06/20 13:09:26 [INFO] Cleaning up temporary folder: C:\Users\volfg\AppData\Local\Temp\buildenv_2022-06-20-1309.426519271
2022/06/20 13:09:26 [FATAL] exit status 1
When I use your example I get:
- GODEBUG=“x509ignoreCN=0” xk6 build --with github.com/mostafa/xk6-kafk …
+ CategoryInfo : ObjectNotFound: (GODEBUG=x509ignoreCN=0:String) [], CommandNotFoundException + FullyQualifiedErrorId : CommandNotFoundException
@volfagnt
You are making a mistake by passing the environment variable as a command. Look at the examples here. This is an excellent resource for learning about global variables, a.k.a. environment variables, in BASH, if you are running xk6 on a GNU/Linux machine.
Update:
I just noticed you are running xk6 in PowerShell, which means that you need to read this, that is, you either set the environment variable in the System Properties -> Advanced -> Environment Variables -> System variables
(and restarting your shell) or you can pass them directly to pwsh.exe
while invoking it like this:
pwsh -Command { $env:GODEBUG="x509ignoreCN=0"; .\xk6 build --with github.com/mostafa/xk6-kafka@latest=. }
Thx, so build new one k6 like that - $Env:GODEBUG =‘x509ignoreCN=0’; ./xk6 build v0.38.3 --with github.com/mostafa/xk6-kafka@v0.11.0
I have created a System variable
And I am passing the certificates as a string, but still get errors(((
My conf
Consumer/producer :
time=“2022-06-21T02:19:44+03:00” level=info msg=“Cannot process TLS config” error=“Client certificate file not found.”
ERRO[0001] panic: runtime error: invalid memory address or nil pointer dereference
goroutine 68 [running]:
runtime/debug.Stack()
runtime/debug/stack.go:24 +0x65
go.k6.io/k6/js/common.RunWithPanicCatching.func1()
go.k6.io/k6@v0.38.3/js/common/util.go:101 +0x191
panic({0xcc3bc0, 0x1b3fd60})
runtime/panic.go:838 +0x207
github.com/dop251/goja.AssertFunction.func1.1()
github.com/dop251/goja@v0.0.0-20220405120441-9037c2b61cbf/runtime.go:2300 +0x6e
github.com/dop251/goja.(*vm).try.func1()
github.com/dop251/goja@v0.0.0-20220405120441-9037c2b61cbf/vm.go:537 +0x635
github.com/segmentio/kafka-go.(*Reader).activateReadLag(0xc000d61d40?)
github.com/segmentio/kafka-go@v0.4.31/reader.go:1142 +0x18
github.com/segmentio/kafka-go.(*Reader).FetchMessage(0x0, {0x1176810, 0xc000d30940})
github.com/segmentio/kafka-go@v0.4.31/reader.go:814 +0x78
github.com/segmentio/kafka-go.(*Reader).ReadMessage(0x0, {0x1176810, 0xc000d30940})
github.com/segmentio/kafka-go@v0.4.31/reader.go:791 +0x9c
github.com/mostafa/xk6-kafka.(*Kafka).consumeInternal(0xc001c90000, _, _, {{{0x0, 0x0}, {0x0, 0x0}, {0x0, 0x0}, 0x0}, …}, …)
github.com/mostafa/xk6-kafka@v0.11.0/consumer.go:120 +0x452
github.com/mostafa/xk6-kafka.(*Kafka).Consume(0x7?, 0x0?, 0xc000ee06c0?, {0x0?, 0x4?}, {0x0?, 0x2?})
github.com/mostafa/xk6-kafka@v0.11.0/consumer.go:61 +0x65
reflect.Value.call({0xdc4120?, 0xc001c90000?, 0x23fd9cd0a28?}, {0xe35efe, 0x4}, {0xc000ff7740, 0x4, 0xc001317210?})
reflect/value.go:556 +0x845
reflect.Value.Call({0xdc4120?, 0xc001c90000?, 0x1955a90?}, {0xc000ff7740, 0x4, 0x4})
reflect/value.go:339 +0xbf
github.com/dop251/goja.(*Runtime).wrapReflectFunc.func1({{0x117f078, 0x1bb77a0}, {0xc000ee63c0, 0x2, 0x12}})
github.com/dop251/goja@v0.0.0-20220405120441-9037c2b61cbf/runtime.go:1886 +0x1c5
github.com/dop251/goja.(*vm)._nativeCall(0xc0018b2400, 0xc001228280, 0x2)
github.com/dop251/goja@v0.0.0-20220405120441-9037c2b61cbf/vm.go:2727 +0x217
github.com/dop251/goja.call.exec(0x7?, 0xc0018b2400)
github.com/dop251/goja@v0.0.0-20220405120441-9037c2b61cbf/vm.go:2699 +0x95b
github.com/dop251/goja.(*vm).run(0xc0018b2400)
github.com/dop251/goja@v0.0.0-20220405120441-9037c2b61cbf/vm.go:408 +0x8b
github.com/dop251/goja.(*baseJsFuncObject)._call(0xc000cc0000, {{0x117f078, 0x1bb77a0}, {0xc002c18de0, 0x1, 0x1}}, {0x0?, 0x0}, {0x117f078, 0x1bb77a0})
github.com/dop251/goja@v0.0.0-20220405120441-9037c2b61cbf/func.go:193 +0x3ff
github.com/dop251/goja.(*baseJsFuncObject).call(...)
github.com/dop251/goja@v0.0.0-20220405120441-9037c2b61cbf/func.go:203
github.com/dop251/goja.(*baseJsFuncObject).Call(0x8?, {{0x117f078, 0x1bb77a0}, {0xc002c18de0, 0x1, 0x1}})
github.com/dop251/goja@v0.0.0-20220405120441-9037c2b61cbf/func.go:156 +0xc7
github.com/dop251/goja.AssertFunction.func1.2()
github.com/dop251/goja@v0.0.0-20220405120441-9037c2b61cbf/runtime.go:2305 +0x74
github.com/dop251/goja.(*vm).try(0xc00057b8c8?, 0x2d805?)
github.com/dop251/goja@v0.0.0-20220405120441-9037c2b61cbf/vm.go:545 +0x176
github.com/dop251/goja.AssertFunction.func1({0x117f078?, 0x1bb77a0?}, {0xc002c18de0?, 0x1?, 0x1?})
github.com/dop251/goja@v0.0.0-20220405120441-9037c2b61cbf/runtime.go:2304 +0x10c
go.k6.io/k6/js.(*VU).runFn.func1.1()
go.k6.io/k6@v0.38.3/js/runner.go:800 +0x43
go.k6.io/k6/js/eventloop.(*EventLoop).Start(0xc00018a9b0, 0xc000ed3bf0)
go.k6.io/k6@v0.38.3/js/eventloop/eventloop.go:112 +0x177
go.k6.io/k6/js.(*VU).runFn.func1()
go.k6.io/k6@v0.38.3/js/runner.go:799 +0xee
go.k6.io/k6/js/common.RunWithPanicCatching({0x117ff20?, 0xc0002e5ab0?}, 0x23fff48984a?, 0xc00057bb90?)
go.k6.io/k6@v0.38.3/js/common/util.go:105 +0x87go.k6.io/k6/js.(*VU).runFn(0xc000cd6000, {0x1176810, 0xc000d30940}, 0xa0?, 0xc00151a570, 0xc002c18dd0, {0xc002c18de0, 0x1, 0x1})
go.k6.io/k6@v0.38.3/js/runner.go:798 +0x2a5
go.k6.io/k6/js.(*ActiveVU).RunOnce(0xc000ce3040)
go.k6.io/k6@v0.38.3/js/runner.go:750 +0x40f
go.k6.io/k6/lib/executor.getIterationRunner.func1({0x11768b8, 0xc000c58c90}, {0x116d300?, 0xc000ce3040?})
go.k6.io/k6@v0.38.3/lib/executor/helpers.go:145 +0x64
go.k6.io/k6/lib/executor.(*activeVUPool).AddVU.func1()
go.k6.io/k6@v0.38.3/lib/executor/ramping_arrival_rate.go:546 +0xd1
created by go.k6.io/k6/lib/executor.(*activeVUPool).AddVU
go.k6.io/k6@v0.38.3/lib/executor/ramping_arrival_rate.go:540 +0x12e
@volfagnt The certificates should be passed as filenames, not strings. Please have a look at this unit test:
Hi! All three certs can be .pem??
@volfagnt According to the following, they must be PEM-encoded:
@volfagnt Keep an eye on this issue and possibly upvote it, so I know if you want to have JKS instead of PEM because I know what a hassle it is to convert them.
I had such a problem on jmeter, if you add bouncycastle lib, then you can bypass jks on spring and java.|
Maybe there is a solution for Go like bouncycastle.
Now for my scenario, I added the ability to create a local file with certificates in .pem from response. But again began to receive an old problem.
My build was like that - $Env:GODEBUG =‘x509ignoreCN=0’; ./xk6 build v0.38.3 --with github.com/mostafa/xk6-kafka@v0.11.0 --with github.com/avitalique/xk6-file@latest
OS Windows Powershell.
@volfagnt According to the following link, the feature flag is removed in Go 1.17, so you can no longer pass the env-var to xk6 and Go while compiling xk6-kafka. You must re-sign your certificate and set subjectAltName
