Hi.
I’m not sure if I’m doing something wrong or if this is a bug. My searching didn’t helped me a whole lot, so therefore I ask here:
I am reading my data off a SQLite database with the sqlite plugin for grafana. When creating a time series by default the legend for the graphs is the same as the column name.
I just noticed, the double names already start coming up if I only use the alias operator on the one query…
(can’t share the screenshot due to limitations)
Additionally I just noticed that this behaviour only happens while I have two query running for the same plot. If I remove one of them I goes back to the desired behaviour.
Can it be connected to the fact that both columns are called “value”? But then I would assume something like “alias1 alias2” to happen. I’m confused.
You shouldn’t have to add an “override” but just use the regular “display name” setting.
This works pretty well in my opinion.
The version 3.1.1 of the plugin will have a bit better naming here but the core issue of more information added to the legend is due to Grafana (especially if using multiple lines in a chart).
