I have the following query, which displays the value nicely but I don’t understand how to change the label. If I put anything in Alias
, the graph is suddenty empty. I guess I have not understand yet what “alias” means
The query looks like this:
SELECT mean("serverrack8") FROM "1-wire" WHERE ("host" = 'ecap-s010')
AND $timeFilter GROUP BY time($__interval) fill(null)
I tried with
SELECT mean("serverrack10"), 'Rack 10' as metric FROM "1-wire" WHERE
("host" = 'ecap-s010') AND $timeFilter GROUP BY time($__interval) fill(null)
But this shows “No data”.
How can I set the legend entry for this? I’d preferably use the field name (in this case serverrack8
) but setting that manually is also fine… where do I do this?
Welcome
Please provide some sample data for your 1-wire db?
host,serverrack8,serverrack10
ecap-s010,20,30
Enough obfuscated sample data to help us help you
The only host is ecap-s010
and the columns are namend serverrack1
… serverrack15
, that’s basically it.
I think that it’s somehow a bug in Grafana since in the Explore
mode, I am able to recreate the graph and when I put anything in ALIAS
, the legend is updated accordingly. If I do the same in the dashboard, the Graph simply resets and does not show anything. I am running Grafana 8.3.4 but will update later to the latest v9, maybe that solves it and then I can manually enter the aliases.
However, if you come up with a solution how to rename them based on the column names, that would already be very helpful. So when selecting mean("serverrack10")
, the legend entry should be serverrack10
. If that is even possible?
OK so I guess it’s because of the older version I am using. I will update today and report back. Many thanks for the cross-check! If I do exactly the same, the legend is 1-wire.mean
I upgraded to Grafana v9.0.2 but still have the same issue. Once I type something into Alias
, I get an empty plot.
Here is before (empty Alias):
and here right after typing something into Alias
what happens when you change it to the a SQL like query like I have it. It could be a bug.
I have the exact same SQL line. Which version do you use? Your label says “Alias by” and mine is “ALIAS”, so there is probably a difference… I am using Grafana 9.0.2 now.
OK I guess it’s a bug then? I’ll go ahead with a bug-report.
let me try it in 9.0.2 also
could be a regression bug
Btw. I ended up upgrading InfluxDB from 1.8 to 2.3 and then used flux
to create the queries. To rename the labels, I am now using the “Transform” functionality with the “Rename regex” one, which is perfect!
I realise that you’ve got this sorted, but I’ve got what I believe is a “fix” which is worth documenting for googlers of the future who stumble across this same issue.
I had set up a dashboard with 2 tables in it, renaming the ALIAS of one table did exactly what I wanted - it renamed the legend. For the other though, it simply hid the data.
What I noticed is that I had a field override set on the chart that wasn’t working.
I selected it and clicked the dustbin/delete button
Then I was able to set the alias
And we’re in business (I left 2 other fields without an alias for comparison)
