I’m running K6 on one of our Kubernetes Clusters as the Operator model. My engineering team wants to create custom module bundles with Webpack and make them available for tests.
I can’t find any documentation on where the bundles can be mounted in the Operator (manager) container. Is this possible and if so how?
If possible, I was going to have my CI build their webpack and copy it into a new image where i would combine with the existing public image.
Hi @nema.darban
Welcome to the forum
You can mount a volume with whatever files you need to run the test as volumeClaim
, see the docs here.
Alternatively, you can build your own image and pass it as runner
to your yaml and use localFile
option, also described in the above README. But I’d say one should try to go with the volume if possible.
Hope that helps!
hi @olha
I feel like I’m making a rudimentary mistake then. I have a PVC that is bound to a Pod used by my CI/CD to build and copy the modules to the Volume.
On that Pod I’m mounting to the path /k6-modules
. I’ve validated the files are there by exec’ing to the pod and checking the volume’s content.
output of pod ls
/ # ls k6-modules/v1/
httpd_test.js script_test.js test.main.js test.main.js.map
mount path for the pod used by ci/cd
volumeMounts:
- mountPath: "/k6-modules"
error i get from my runner
time="2022-08-06T00:16:19Z" level=error msg="The moduleSpecifier \"/test/v1/script_test.js\" couldn't be found on local disk. Make sure that you've specified the right path to the file. If you're running k6 using the Docker image make sure you have mounted the local directory (-v /local/path/:/inside/docker/path) containing your script and modules so that they're accessible by k6 from inside of the container, see https://k6.io/docs/using-k6/modules#using-local-modules-with-docker."
This is my K6 config
# https://github.com/grafana/k6-operator/blob/main/README.md#parallelism
apiVersion: k6.io/v1alpha1
kind: K6
metadata:
namespace: chaos
spec:
parallelism: 10
arguments: --out statsd
script:
volumeClaim:
file: v1/script_test.js
runner:
env:
- name: K6_STATSD_ENABLE_TAGS
value: "true"
- name: K6_STATSD_ADDR
value: datadog.datadog:8125
Is there anything else i can provide to help debug?
Hi @nema.darban,
It seems like there might be an issue with the path. As you can see in the error message, k6-operator seeks the JS in /test
folder, i.e. /test/v1/script_test.js
. But it seems like your file is in /k6-modules
instead. Is it possible to move it to /test
? This is hard-coded at the moment and cannot be changed.
I’ve created an issue to make it less dependent on hard-coded values here but can’t promise when that particular improvement will happen.
