When running with the following config:
apiVersion: k6.io/v1alpha1
kind: K6
metadata:
spec:
parallelism: 1
arguments: --out statsd
script:
localFile: /app/tests/load/scriptv1.js
runner:
image: some.custom.repo:latest
serviceAccountName: k6-runner
I am presented with the following error:
manager 2022-06-27T23:31:47.730Z ERROR controllers.K6 Failed to launch k6 test {"k6": "default/one-load-test", "error": "Job.batch \"one-load-test-1\" is invalid: [spec.template.spec.volumes[0].name: Required value, spec.template.spec.containers[0].volumeMounts[0].name: Required value, spec.template.spec.containers[0].volumeMounts[0].name: Not found: \"\", spec.template.spec.containers[0].volumeMounts[0].mountPath: Required value]"}
manager github.com/go-logr/zapr.(*zapLogger).Error
manager /go/pkg/mod/github.com/go-logr/zapr@v0.1.0/zapr.go:128
manager github.com/grafana/k6-operator/controllers.launchTest
manager /workspace/controllers/k6_create.go:80
manager github.com/grafana/k6-operator/controllers.createJobSpecs
manager /workspace/controllers/k6_create.go:51
manager github.com/grafana/k6-operator/controllers.CreateJobs
manager /workspace/controllers/k6_create.go:24
manager github.com/grafana/k6-operator/controllers.(*K6Reconciler).Reconcile
manager /workspace/controllers/k6_controller.go:70
manager sigs.k8s.io/controller-runtime/pkg/internal/controller.(*Controller).reconcileHandler
manager /go/pkg/mod/sigs.k8s.io/controller-runtime@v0.6.2/pkg/internal/controller/controller.go:235
manager sigs.k8s.io/controller-runtime/pkg/internal/controller.(*Controller).processNextWorkItem
manager /go/pkg/mod/sigs.k8s.io/controller-runtime@v0.6.2/pkg/internal/controller/controller.go:209
manager sigs.k8s.io/controller-runtime/pkg/internal/controller.(*Controller).worker
manager /go/pkg/mod/sigs.k8s.io/controller-runtime@v0.6.2/pkg/internal/controller/controller.go:188
manager k8s.io/apimachinery/pkg/util/wait.BackoffUntil.func1
manager /go/pkg/mod/k8s.io/apimachinery@v0.18.6/pkg/util/wait/wait.go:155
manager /go/pkg/mod/k8s.io/apimachinery@v0.18.6/pkg/util/wait/wait.go:156
manager k8s.io/apimachinery/pkg/util/wait.JitterUntil
manager /go/pkg/mod/k8s.io/apimachinery@v0.18.6/pkg/util/wait/wait.go:133
manager k8s.io/apimachinery/pkg/util/wait.Until
manager /go/pkg/mod/k8s.io/apimachinery@v0.18.6/pkg/util/wait/wait.go:90
This seems like it may be a regression of localFile feature is broken · Issue #111 · grafana/k6-operator · GitHub
