Loki flush logs to persistent storage on shutdown
Hello
We are evaluating loki as a logging solution to handle TB’s of logs daily to go into S3.
For the trial, we used a docker compose setup like below. The random logger prints log lines and those do appear in grafana, but we notices that if we shutdown loki normally (sudo docker-compose down loki) withing say 30s of starting, the logs in memory are not flushed to disk. Because of our huge volume, we do not want to use WAL.
Is there a way to tell loki ingester to flush all data to persistent storage when the process is shutdown (SIGTERM).
services:
  loki:
    container_name: loki
    image: grafana/loki:latest
    ports:
      - "3100:3100"
    command: -config.file=/etc/loki/loki-local-config.yaml
    volumes:
      - ./:/etc/loki
      - ./loki-data:/tmp
  grafana:
    container_name: grafana
    depends_on:
      - "loki"
    image: grafana/grafana:latest
    ports:
      - 80:3000
    volumes:
      - ./grafana-data:/var/lib/grafana # grafana-data has grafana persistent data
  random-logger:
    container_name: random-logger
    depends_on:
      - "loki"
    logging:
      driver: loki
      options:
        loki-url: "http://localhost:3100/loki/api/v1/push"
    #image: chentex/random-logger:latest
    #command: 100 400 10
    image: bash
    command: bash /tmp/seq.sh
    volumes:
      - ./seq.sh:/tmp/seq.sh
seq.sh is this
count=1
while (( 1 )); do
        echo "message id [$count]"
        count=$(( count + 1 ))
        sleep 1
done
Loki config is this
auth_enabled: false
server:
  http_listen_port: 3100
ingester:
  lifecycler:
    address: 127.0.0.1
    ring:
      kvstore:
        store: inmemory
      replication_factor: 1
    final_sleep: 0s
  chunk_idle_period: 5m
  chunk_retain_period: 30s
schema_config:
  configs:
    store: boltdb
    object_store: filesystem
    schema: v11
    index:
      prefix: index_
      period: 168h
storage_config:
  boltdb:
    directory: /tmp/loki/index
  filesystem:
    directory: /tmp/loki/chunks
limits_config:
  enforce_metric_name: false
  reject_old_samples: true
  reject_old_samples_max_age: 168h
regards
aniruddha
