Loki - Pattern parser is missing
Hi all
I’m starting to work with Loki and following the guide example, I cannot find “Pattern” (and “Unpack”) from the available parsers.
I need to install some plugin? I’m working with Loki 2.8.0 and Grafana 7.5.2
Thank you
Welcome
Latest loki is 2.8 2. Any reason you cannot uograde your grafana as well? Grafana 7 is probably no longer supported
wow!!!
Thank you very much for your rapid answer.
I’ve followed the guide here: Install Grafana Loki with Docker or Docker Compose | Grafana Loki documentation
and it reports the version 2.8.0; I didn’t know there was a newer version. Ok, I’ll update soon.
About Grafana, I’m using the docker image “grafana/grafana:latest” that should be the last one. I do not know because in the bottom-left popup reports this number; is there a way to check the real versione number?
Ops, sorry!
I’m using “grafana/grafana:latest” docker image but my last image download was two years ago!
Ok, I’ll remove the image and I’ll get the last stable version 9.5.2.
Thank you again.
Are you upgrading or starting from scratch?
started from scratch.
