Loki query filter out row with level=info
Hi, I’m using Grafana 9.3.2 and I got a LOLI data source.
It’s a simple page with 4 graphs.
My query is like
{job=~"$app"}
|= "$search"
| logfmt
and I would like to filter our all row with level=info
Sincerely, I read some explanation but I did not succeed.
Could you tell me the way without interacting with the Grafana configuration file of course?
Thanks Alen
Try this:
{job=~"$app", level ="info"}
|= "$search"
| logfmt
Regards,
Fadjar
Hi and thanks for your reply…
but maybe I wrote wrongly…
it’s the reverse… all rows that aren’t info level!
I try with…
but, as you can see, with refresh query I always see that level (info).
ALEN
If there aren’t expected, you can see in the explorer to see the detail data in the job that you want to query.
If I know the detail of the data, there’s lot easier to analyze it…
You can redacted the important data, except the text that you want to display.
Regards,
Fadjar
