What ipaddr are requests comming from when using grafanacloud ?
Not sure what you are asking but think it might be the same as this question: Grafana changing IP
Hello Daniel,
Yes it is the problem i also issue.
But when i try to configure mysql connections i can’t find anything about TLS its only in Graphite data sources ?
For the MySQL data source, I think you will have to use a proxy - nginx or ProxySQL to get TLS. There is support for TLS if using MySQL as the data store for Grafana but we haven’t added that to the MySQL data source yet.
