ah gotcha. but I think that is a bug in grafana, not sure why it takes over when decimal is on auto.
Thanks for the reply. Seems so. The problem is most probably with the valueFormat function. not an expert on JavaScript.
thanks for the tips. the data is basically there. it just does not show up in certain visualization. the search for decimal and removal of ‘auto’ did the trick.
tested it in console log and I think you are correct
decimals is 0
Added a bug
opened 08:58PM - 04 Aug 22 UTC
closed 02:42PM - 19 Aug 22 UTC
type/bug
area/grafana/data
**What happened**:
negative decimal numbers' decimals get dropped
**What you… expected to happen**:
i expect the auto decimal setting to respect my numbers :)
**How to reproduce it (as minimally and precisely as possible)**:
using microsoft sql server as data source and fake data
select getdate() time, -27.5 value
The value is rounded to -27 with decimal set to auto. if one changes it to 1 then it works. but auto should respect my numbers.
Self debugging getDecimalsForValue in dev console.
The issue is here
https://github.com/grafana/grafana/blob/2107652c3fdeebf499c360795c219f68ef47b65f/packages/grafana-data/src/valueFormats/valueFormats.ts#L82
getDecimalsForValue function. Also looks like it is missing a unit test for neg values.
**Anything else we need to know?**:
**Environment**:
- Grafana version: 9.0.3
- Data source type & version: inline csv
- OS Grafana is installed on: Windows
- User OS & Browser: Windows/Chrome
- Grafana plugins: infinity
- Others:
seems like it is now fixed
grafana:main
← grafana:joao_silva/decimal-fix
opened 02:18PM - 19 Aug 22 UTC
**What this PR does / why we need it**:
If you leave the "Decimals" option se… t to auto, negative and positive values behave differently:
This PR makes sure that there is no difference between how those are displayed and adds some tests for those cases.
**Which issue(s) this PR fixes**:
Fixes #53331
