grafana version: 8.5.0 OSS
data source: mysql (local)
OS: Windows
Trying to connect my 2 mysql queries to the NodeGraph plugin. My data has two frames nodes/edges. Per the Data Api Node graph | Grafana documentation, I believe I have all the is needed but the nodes are not plotting, I get No Data
How query/data looks like?
here you go
drop table IF EXISTS nodes;
create table IF NOT EXISTS nodes(id int, title varchar(50),
mainStat integer,
arc__passed float,
arc__failed float);
insert into nodes(id, title, mainStat, arc__passed, arc__failed)
values(1,'nginx',21233,0.283,0.717),
(2,'serviceA',12000,0.167,0.833),
(3,'serviceB',8233,0.486,0.514);
drop table IF EXISTS edges;
create table IF NOT EXISTS edges(id varchar(50), source int, target int);
insert into edges(id, source, target)
values('fasdfdfsfa',1,2);
Interesting that mysql plugin only has the following format types
export type ResultFormat = 'time_series' | 'table';
maybe I should do a pull request if this effort does not pan out.
It works for me. Grafana 8.5.2 - you don’t need a real tables for simple testing:
Start with this simple example and if it works fine, then add more fields. Fields are/have been case sensitive, so keep in mind mainstat
!=mainStat
. You can starts with nodes only, maybe string edge id is a problem.
nice! let me upgrade and see what happens. thanks so much @jangaraj
