How do you allow the Orchestra Cities Plugin to show multiple events per marker? You can see in the raw data table that it has two events with different timestamps
but on the map the marker will only show one event per lookup location marker
This is using a host to pull the lon,lat from a gazetteer json file.
interesting that it does not work in Orchestra but does work in GeoMap
It is. I was using orchestra for some of the other features like layers and being able to select what data. Really I want to use a location name from the gazeetteer file as the pop up title and then a dropdown of problems at that lon/lat location.
