Permissions Regarding Viewer Role in Grafana
Hi all,
I have created a user in GRAFANA and have assigned viewer role to the user. Every thing works fine but I don’t want the View Only User to change the preferences on its own. (e.g. Theme Change UI Dark or Light Whatever). Is there any possibility to restrict the user on theme that has been granted from the admin user.
Looking for the strongest community response towards this so that I can overcome this problem.
Thankyou.
I don’t think that faisable (unless you force the theme using html/css modification, but not recommended) , since the requirement to force a theme or other preferences for user is not considered normal situation, unless you have specific goal. You can always raise a Request for enhancement in GitHub.
Hope it helps.
Good Luck
