I added 3 pie chart to my dashboard.
When I change the time range and the data is changing, the radius of the pie chart is changing.
I didnt see any reason (It is not like one day the data is very long and another is short…)
Is there a way to define a constant size? I want all the chart will have the same size and that size will not change.
I am using hosted grafana.
Thank you!
example 1:
example 2:
example 3:
