I am a total beginner to both Grafana and also postgresql. Please forgive my possible newbie question. I have searched in the community but could not find an answer.
I have some data in an 8 element array of temperatures stored in postgresql.
CREATE TABLE temparray (
time TIMESTAMPTZ NOT NULL,
temp real[8]
INSERT INTO temparray(time, temp) VALUES(NOW(), ARRAY[100,200,350,400,500,200,600,450]);
SELECT * FROM temparray;
time | temp
2020-03-27 16:31:41.119538-10 | {100,200,350,400,500,200,600,450}
When I try to plot in Grafana, it does not see this variable. It only shows “value”. When I type the name of the variable temp, I get the following error.
Value column must have numeric datatype, column: temp type: string value: {100,200,350,400,500,200,600,450}
I can edit the sql query and plot individual variables such as temp[1], temp[2], etc. one at a time. I can also put all of them but then it treats it all as one variable.
Is there a way to plot all 8 of variables on the same plot with different colors. I suppose I could save the data in the array as temp1, temp2, etc. instead of an array and then those could be picked. Unfortunately, doing that for somewhat large arrays may not be as practical.
Thanks.
Edit to add: I was able to get all 8 array elements to show on the same plot by using some SQL. e.g temp[1] as “temp1”, temp[2] as "temp2’, …, temp[8] as “temp8”. I wonder if this can be automated.
