Hello.
Im having problems when using some data from my postgres database.
Im unable to print that column in grafana even if i cast conver to varchar de data, i only see “No points available”. Any suggestions?
Thanks in advance
Hello.
Thanks in advance
in query editor you can view genereated SQL can you look at that and test that manually ?
If i test it manually it works flawlessly, also, im getting this error:
If i execute the query manually at postgres i get no problem:
Also, i cast converted the “VALUE”::VARCHAR(5) which removes the error, but shows me no data.
You need to select 3 columns for Grafana: time, metric (=metric name), value (=metric value).
At the moment you are selecting only 2 + metric name is a metric value in your case.
I ended up working it around like this:
SELECT
$__time(“DATETIME”),
“VALUE” as in
FROM “STORAGE”
WHERE(
$__timeFilter(“DATETIME”)
AND “RELATIVE_ID” = 47) AND “VALUE” != ‘NaN’
ORDER BY 1
Turns out, there were a few NaN values inside the database…
Thanks everyone for your support!
