I’m trying to plot a simple graph of the number of ‘max’ connections in a MySQL instance, from the ‘information_schema’ database using the MySQL datasource. The following query works on the MySQL command line, but if I try to make a “Time Series” it gives me a “blank” graph, not sure why. Any ideas?
SELECT UNIX_TIMESTAMP() as time, variable_value as value FROM global_status WHERE variable_name = ‘MAX_USED_CONNECTIONS’ order by time asc
Output of query in MySQL:
mysql> SELECT UNIX_TIMESTAMP() as time, variable_value as value FROM global_status WHERE variable_name = ‘MAX_USED_CONNECTIONS’ order by time asc;
| time | value |
| 1531844841 | 911 |
1 row in set (0.00 sec)
