Prometheus Annotation Issue
I am trying to create Annotations with Prometheus using the timestamp as the metric.
ansible_deploy{app=“infrastructure”} >= time()-60
with a 60s step
This query works in Prometheus but not in Grafana.
Any thoughts?
Does Grafana only support metric values of 1 or 0?
No, it definitely supports other values.
Can you explain a bit more. What does the query return in Prometheus?
You can compare the query and response by using the Chrome Dev Tools and the network tab. See this guide.
@daniellee
I’m having a similar issue: my prometheus query is properly displaying as a range vector with values between 0 and 1, but annotations are not displayed in panels
Here is my promql query:
max ( #over the web nodes maintaining counters
  increase(concourse_builds_finished{bosh_deployment=~"$bosh_deployment",status="succeeded",exported_job="hard-reset-features-merged"}[5m]) > bool 0
Prometheus data source | Grafana documentation mentions a “regular metric query” but I’m not sure whether this means a prometheus “Range vector” ?
Manually defined annotations are properly displayed within multiple panels, but query annotations do not display
Are annotations not displayed because of the step param filtering out events ?
additional screenshots:
additional screenshots 2/2
