I’m having a similar issue than https://localhost:3000/t/prometheus-annotation-issue/1537 when trying to draft a prometheus query to be used to fetch annotation events.
My prometheus query returns 0 and 1, but after adding it to annotations, I don’t see it displayed.
my prometheus query is properly displaying as a range vector with values between 0 and 1, but annotations are not displayed in panels
Here is my promql query:
max ( #over the web nodes maintaining counters
increase(concourse_builds_finished{bosh_deployment=~"$bosh_deployment",status="succeeded",exported_job="hard-reset-features-merged"}[5m]) > bool 0
docs at docs/features/datasources/prometheus/#annotations mentions a “regular metric query” but I’m not sure whether this means a prometheus “Range vector” ?
Manually defined annotations are properly displayed within multiple panels, but query annotations do not display
Are annotations not displayed because of the step param filtering out events ?
I had posted additional screenshots in the related issue linked above (given new users are limited to 2 post, I’m not reposting them here to avoid too much spam)
Should I instead find a promql query that only return the 1 value ? I did not manage to do so. Failed so far to get inspiration from other online examples such as wikitech.wikimedia.org
Thanks in advance for your help
