My intentions is to include telemetry to our .net application and i was testing just building up a system locally following the guide : Instrumenting a .NET web API using OpenTelemetry, Tempo, and Grafana Cloud | Grafana Labs
but after I have everything setup I get this error message from the agent-config.yaml file:
error loading config file /etc/agent-config.yaml: yaml: unmarshal errors:
grafana-agent_1 | line 2: field receivers not found in type tempo.plain
(screenshot with more information)
It’s probably just something in my way of setting all up, I did try to follow the guide step for step and even got the example application from: GitHub - mdisibio/tempo-otel-dotnet-example: Example repo showing how to instrument a .NET 5.0 web api with OpenTelemetry.Net and send logs and traces to Grafana Cloud
Thank you!
