- What Grafana version and what operating system are you using?
Grafana 8.4.4
Grafana Official Docker Image
- What are you trying to achieve?
See the userid and username in Router Logs
- How are you trying to achieve it?
Enabling the router_logging option
- What happened?
I’m using AzureAD as an Identity Provider and in the previous Grafana version that I was using 7.6, I was able to see the user ids and names in the router Logging
- What did you expect to happen?
In Grafana 8 I would like to keep seeing the userid and uname in the router logs
- Can you copy/paste the configuration(s) that you are having problems with?
Just enabling Azure AD authentication and enabling the router_logging
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No errors.
- Did you follow any online instructions? If so, what is the URL?
