Same filter for all panels in dashboard
  • v8.5.2 (90701be19)
    I would like to have my entire dashboard be filtered with some custom filter I create based on some query variables.
    I have several query variables at the top of the dashboard that the user can multiselect, and in all of the panels, there is the same where-clause that is based on these variables.
    Every time I change/add a variable, I need to go to all of the panels and update the query.
    I’d like a way to create a where-clause that will interpolate the variables and be inserted to my bigquery query.
    I tried using custom/constant/text box but it seems like variable chaining is only supported in query variables.
    Also ad hoc filters are no use as they don’t support bigquery
    Couldn’t find any. Everywhere seems to lead to no solution :frowning:
Hi atlanteh, which syntax and database are you currently using ? :slight_smile:
@grafunkel thanks for your message!
I’m using bigquery with the sql syntax (not the builder).
Hi atlanteh, i am not really into sql and grafana variables, but if i remember right you can achieve these variables if you just query over your data columns and SELECT every DISTINCT entity if i am right.
This should help with creating a grafana variable.
The other subject regarding querying your variables:
i ve found some old post regarding this. Someone has linked their variables inside their sql syntax like that:
Hope it helps
Grafu
I am using variables, the problem is that I have a dashboard with about 7 variables, that all panels use exactly the same, so every time I need to tweak the query I need to go to all panels and update the, where I prefer to have a simple variable that would hold the “where” clause with all other variables. the problem is that variable interpolation only works for query variables, not custom/text variable
