What should be exactly the proper value for the Request Body?
Grafana v9.0.0
Ubuntu 20.04.4 LTS -
Create a Synthetic Monitoring Check with request method POST -
Create a check with Request Method: POST and Request Body: {“key1”: “value1”, “key2”: “value2”} (replaced with proper key name and value name) -
What happened?
I Keep on getting status_code 400 even if my request body is correct -
Expect a 200 status code -
i just replaced with key1 and value1 due to sensitive information -
Did you follow any online instructions? If so, what is the URL?
no
