MacOS, 13.3 with Safari and Microsoft Edge
Grafana 9.4.7 Community Edition -
I have absolute values and percentage values in one table panel.
The percentage value is in total 100% and can shift between 0% and 100%. 50% means neutral.
I want to display the bias of Short and Long positions for financial stock market data. -
I set up view in the local database and connected it with the table panel.
I used the override feature to apply the cell type “Gauge” to the percentage value. -
What happened?
The optical representation was only one / two pixel on the left of the bar no matter if the Bias was at 10% or 90%.
When clicking “replacing all fields”, the gauge looked better. But I like to have values and optical support.
Assumption: As there are absolute and percentage values on the same line, Grafana sets a value of 0.8 (for 80%) into the scale of absolute values like 185,432.
- What did you expect to happen?
I wanted to see the bias as the following:
- When above 50: moving from the middle of the bar to the right with thresholds of different green intensity.
. When below 50: moving from the middle of the bar to the left with several levels of red.
- Can you copy/paste the configuration(s) that you are having problems with?
"datasource": {
"uid": "000000006",
"type": "mysql"
"fieldConfig": {
"defaults": {
"custom": {
"align": "auto",
"cellOptions": {
"type": "auto"
"inspect": false
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "semi-dark-blue",
"value": null
"color": {
"mode": "thresholds"
"unit": "locale"
"overrides": [
"matcher": {
"id": "byName",
"options": "NC Long (%)"
"properties": [
"id": "unit",
"value": "percentunit"
"id": "decimals",
"value": 0
"id": "custom.width",
"value": 122
"matcher": {
"id": "byName",
"options": "NC Short (%)"
"properties": [
"id": "unit",
"id": "decimals",
"value": 0
"value": 129
"matcher": {
"id": "byName",
"options": "Com. Long (%)"
"properties": [
"id": "unit",
"id": "decimals",
"value": 0
"value": 117
"matcher": {
"id": "byName",
"options": "Com. Short (%)"
"properties": [
"id": "unit",
"id": "decimals",
"value": 0
"value": 87
"matcher": {
"id": "byName",
"options": "Com. Long"
"properties": [
"value": 176
"matcher": {
"id": "byName",
"options": "Markt"
"properties": [
"value": 83
"matcher": {
"id": "byName",
"options": "NC Long"
"properties": [
"value": 93
"matcher": {
"id": "byName",
"options": "NC Short"
"properties": [
"value": 117
"matcher": {
"id": "byName",
"options": "NC Gesamt"
"properties": [
"value": 100
"matcher": {
"id": "byName",
"options": "Com. Short"
"properties": [
"value": 107
"matcher": {
"id": "byName",
"options": "Com. Gesamt"
"properties": [
"value": 132
"matcher": {
"id": "byName",
"options": "CoT-Datum"
"properties": [
"id": "unit",
"value": "time:DD.MM.YYYY"
"id": "custom.align",
"value": "center"
"value": 116
"matcher": {
"id": "byName",
"options": "Markt"
"properties": [
"id": "links",
"value": [
"title": "",
"url": "https://grafana.trading.meinzuhau.se/d/_5k03OlVk/03-9-cot-daten-veranderung-historie?orgId=2&grafana_commodity=${__idCommodity}"
"matcher": {
"id": "byName",
"options": "idCommodity"
"properties": [
"id": "custom.hidden",
"value": true
"matcher": {
"id": "byRegexp",
"options": ".+\\sBias"
"properties": [
"id": "unit",
"id": "custom.cellOptions",
"value": {
"type": "gauge",
"valueDisplayMode": "color"
"gridPos": {
"h": 24,
"w": 24,
"x": 0,
"y": 0
"id": 2,
"options": {
"showHeader": true,
"cellHeight": "sm",
"footer": {
"show": false,
"reducer": [
"sum"
"countRows": false,
"fields": []
"sortBy": []
"pluginVersion": "9.5.3",
"targets": [
"datasource": {
"type": "mysql",
"uid": "000000006"
"dataset": "trading",
"editorMode": "builder",
"format": "table",
"rawQuery": true,
"rawSql": "SELECT commodity_shortsign AS \"Markt\", noncom_long AS \"NC Long\", noncom_short AS \"NC Short\", noncom_total AS \"NC Gesamt\", noncom_long_pct AS \"NC Long (%)\", noncom_short_pct AS \"NC Short (%)\", com_long AS \"Com. Long\", com_short AS \"Com. Short\", com_total AS \"Com. Gesamt\", com_long_pct AS \"Com. Long (%)\", com_short_pct AS \"Com. Short (%)\", cot_date AS \"CoT-Datum\", com_bias AS \"Com Bias\", noncom_bias AS \"NC Bias\" FROM trading.Grf_Cot_Weekly_Change_with_ComSpreads LIMIT 50 ",
"refId": "A",
"sql": {
"columns": [
"alias": "\"Markt\"",
"parameters": [
"name": "commodity_shortsign",
"type": "functionParameter"
"type": "function"
"alias": "\"NC Long\"",
"parameters": [
"name": "noncom_long",
"type": "function"
"alias": "\"NC Short\"",
"parameters": [
"name": "noncom_short",
"type": "function"
"alias": "\"NC Gesamt\"",
"parameters": [
"name": "noncom_total",
"type": "function"
"alias": "\"NC Long (%)\"",
"parameters": [
"name": "noncom_long_pct",
"type": "function"
"alias": "\"NC Short (%)\"",
"parameters": [
"name": "noncom_short_pct",
"type": "function"
"alias": "\"Com. Long\"",
"parameters": [
"name": "com_long",
"type": "function"
"alias": "\"Com. Short\"",
"parameters": [
"name": "com_short",
"type": "function"
"alias": "\"Com. Gesamt\"",
"parameters": [
"name": "com_total",
"type": "function"
"alias": "\"Com. Long (%)\"",
"parameters": [
"name": "com_long_pct",
"type": "function"
"alias": "\"Com. Short (%)\"",
"parameters": [
"name": "com_short_pct",
"type": "function"
"alias": "\"CoT-Datum\"",
"parameters": [
"name": "cot_date",
"type": "function"
"alias": "\"Com Bias\"",
"parameters": [
"name": "com_bias",
"type": "function"
"alias": "\"NC Bias\"",
"parameters": [
"name": "noncom_bias",
"type": "function"
"groupBy": [
"property": {
"type": "string"
"type": "groupBy"
"limit": 50
"table": "Grf_Cot_Weekly_Change_with_ComSpreads"
"title": "CoT-Daten - Marktübersicht",
"transformations": [
"id": "organize",
"options": {
"excludeByName": {},
"indexByName": {
"CoT-Datum": 1,
"Com. Gesamt": 9,
"Com. Long": 8,
"Com. Long (%)": 10,
"Com. Short": 7,
"Com. Short (%)": 11,
"Markt": 0,
"NC Gesamt": 4,
"NC Long": 3,
"NC Long (%)": 5,
"NC Short": 2,
"NC Short (%)": 6,
"idCommodity": 12
"renameByName": {}
"type": "table"
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No.
- Did you follow any online instructions? If so, what is the URL
Table | Grafana documentation
