I have configured a Singlestat panel which get information on how much disk space is used on a server from an InfluxDB. However I’m wondering if it is somehow possible to set the thresholds to a percentage instead of a static number?
And also if it is possible to set the max value in a gauge as a variable?
Since the disk can be expanded I would have to manually reconfigure the panel for the new values everytime.
@patricf, I need to do the same thing and am curious where you landed with this. We’re you able to use sources from your db for the thresholds in the gauge?
