Use query for field "Max" value in gauge visualization
Hi everyone!
I’m using Grafana 7.0.6 and need your help with creating a gauge visualization.
The goal is to visualize disk usage of some linux VMs and configuring the “Max” value dynamicly.
Using a fix value for the “Max” field, everything is working fine, but, of cause, nearly every VM has different disk sizes. Here’s a screenshot of what I need (with fix value):
I wrote a query, witch result is exactly the value I need, but how can I get this value in the “Max” field?
Here’s a screenshot of what I mean:
As a next step, I will have to do the same for the “threshold” fields. Does anybody know if this will be possible in the same way?
Hopefully somebody does understand what my problem is.
Many thanks in advance and best regards! :slight_smile:
Why not use the threshold in percentage mode? Then it won’t matter what the specific value is.
Hi Diana,
of cause, you’re so right… sometimes, the solution is so easy :smiley:
Thank you so much!
But what about my first question? How do I get the volume size in the “Max” field?
Best regards!
Hello everyone,
I solved it by myself :slight_smile:
The solution is to select two fields in one query, instead of using two queries, and select the field that should be included in the panel.
That’s it! :slight_smile:
