Hi all,
I’ve counter metrics suppose for example:
sample_data{job=“test”,organizationid=“186258c2-c107-4148-8487-62b2c32458cc”}
this metric is pushed to prometheus through pushgateway.
Now I want to use this metric in Grafana with Singlestat in such a way that:
if the time of sample_data_created < 10 min then singlestat panel should turn red if it is less than 30 min it should turn to yellow and if it is less than 1 hour then it should turn green.
I would really very appreciate it if someone please guide me on how can I achieve this or apart from singlestat panel is there any other workaround of this.
