Problem.
What would be a minimal working example of sending a query to a datasource without having any specific associated panel?
In the timepicker panel I’ve added an editor to submit a user-provided query which would be used to query the database for the most recent data time.
The panel is looking like this at the moment:
I enable the persistence of the stored query by adding it to the panel as $scope.ctrl.panel.storedQuery
in app/features/dashboard/timepicker/timepicker.ts
Question.
- How do I go about submitting the actual query to Grafana so that it then sends it to the MySQL server?
I was trying to implement this in a database-agnostic way.
So far I have the following function which is called when my “Save Query” button is clicked, but I’m unsure where to add the query string itself:
saveTimeCheckQuery() {
this.$scope.ctrl.rawSql = $('code-editor .ace_content .ace_text-layer')
.children()
.eq(0)
.text();
this.$scope.ctrl.storedQuery = this.$scope.ctrl.rawSql;
this.$scope.ctrl.panel.storedQuery = this.$scope.ctrl.storedQuery;
const rangeRaw = {
to: 'now',
const range = {
to: '2045-10-31T12:33:44.866Z',
raw: rangeRaw,
const metricsQuery = {
//timezone: this.dashboard.getTimezone(),
//panelId: this.panel.id,
//dashboardId: this.$scope.ctrl.dashboard.id,
range: range,
rangeRaw: range.raw,
interval: '5s',
//intervalMs: 60000,
//{ "refId": "B", "target": "upper_75" }
//targets:
//targets: [this.currentDatasource.queryModel.target],
maxDataPoints: 2495,
//scopedVars: {},
cacheTimeout: null,
format: 'json',
this.$scope.ctrl.panel.mostRecentDataTime = this.$scope.ctrl.currentDatasource.query(metricsQuery);
Other questions:
- This JSON sample was based on GitHub - grafana/simple-json-datasource: Datasource that sends generic http requests to give url but I don’t understand how to add the query itself. The JSON looks like it would be the result of parsing a user query. How would I do this here?
- Because I’m implementing this on the
TimePickerCtrl
, as far as I know, it is a panel without an ID, so I don’t think I’ll be adding it in thismetricsQuery
JSON. I imagine the dashboard variables can be used to query the database without being associated to a specific panel - how to achieve the same result here?
Reason.
I’m looking at Grafana’s source to implement a way for the user to define for each dashboard a domain-specific query to get the most recent time of the data.
One may have different tables in a database and need to implement some custom logic to define what is the most recent time range.
https://localhost:3000/t/reuse-paneleditor-for-dashboard-settings/11918
