I am trying to pull Grafana dashboard as a panel iframe but I get the results in my browser’s timezone whereas I want timestamp to be in EST (UTC-5).
Here is the URL string I am working with. We are using Grafana 7.3.7 in our company.
[http://grafana /d-solo/p-G3DKeGk/***-iot?orgId=1&tz=05%3A00&from=1625108400000&to=1625140800000&…
Could you please provide suggestions on this.
I have the same issue, I guess.
Using the URL var “&tz=UTC+02:00” or “&tz=Europe/Zurich” nothing happens.
Do you find a solution?
Can somebody help us?
Thank you
Daniele
gfrunza
September 7, 2022, 8:45am
3
Hi
Did anybody solve this?
pooh
September 7, 2022, 9:04am
4
Unfortunately it seems that this “feature which doesn’t work” (is that the
same as a bug?) is not worthy of being fixed:
opened 01:48AM - 25 Jun 22 UTC
closed 01:19PM - 28 Jul 22 UTC
type/feature-request
area/dashboard/timezone
not implemented
bot/close feature request
Please use this template to create your bug report. By providing as much i… nfo as possible you help us understand the issue, reproduce it and resolve it for you quicker. Therefore take a couple of extra minutes to make sure you have provided all info needed.
PROTIP: record your screen and attach it as a gif to showcase the issue.
- Questions should be posted to: https://localhost:3000
- Use query inspector to troubleshoot issues: https://bit.ly/2XNF6YS
- How to record and attach gif: https://bit.ly/2Mi8T6K
**What happened**:
Opening a URL like https://play.grafana.org/d/000000016/1-time-series-graphs?orgId=1&tz=UTC shows the dashboard in browser time.
**What you expected to happen**:
I expected this query parameter to change the dashboard's timezone to UTC. The codebase has various testcases that pass tz=Europe/Stockholm but that does not seem to take any effect.
**How to reproduce it (as minimally and precisely as possible)**:
Open https://play.grafana.org/d/000000016/1-time-series-graphs?orgId=1&tz=UTC and look at the time picker to display the timezone in UTC instead of browser local time.
**Anything else we need to know?**:
**Environment**:
- Grafana version: 9.x
- Data source type & version: Various
- OS Grafana is installed on: Linux?
- User OS & Browser: Chrome
- Grafana plugins:
- Others:
“This feature request has been open for a long time with few received upvotes
or comments, so we are closing it.”
Antony.
