I’m trying to connect “AWS graphana(graphana running on AWS)” with localhost system “MySQL database”. But i get an error while trying to do so. It says “db query error: failed to connect to server - please inspect Grafana server log for details”.I have tried multiple methods to get of this error but failed to get rid of so.
Is AWS Grafana able to connect with ANY of your locally hosted data sources? My gut feeling is that the AWS security rules entailed in your AWS instance must be modified to see your local LAN system.
=>No, it is not able to connect with any databases whether the database is hosted on my PC or whether the database is hosted on the web. In both cases, the error i got is “504 gateway timeout”.
My gut feeling is that the AWS security rules entailed in your AWS instance must be modified to see your local LAN system.?
=>I too am feeling the same i.e, it is do more with AWS. But the thing is, with respect to ‘AWS graphana’ i did not find any security rules(AWS not provided this feature). I am attaching the image for the same.
regards to yosiasz question,2nd even if you use your ip.address it has to be exposed to the public, have you done so?
=> Yes i have exposed it to public, as you can see at bottom of attached image.
Your question is more networking than a grafana issue?
=>I agree. But if you can tell where do i need to change the setting because for me, i have tried changing some settings but thing still didn’t worked for me.
