This has been cross posted to github as a bug report, you can view my uploaded gif showing the issue there (image was too large to upload here):
opened 04:22PM - 15 Feb 23 UTC
needs more info
**What happened**: Successfully created playlist, but it won't play saying Playl… ist not found. When I try to edit/delete the playlist it gives the same error
**What you expected to happen**:
Play the list successfully
**How to reproduce it (as minimally and precisely as possible)**:
Add list with a couple of dashboards, then try to play the playlist and get an error every time.
**Anything else we need to know?**:
**Environment**: docker
- Grafana version: v9.3.6 (978237e7cb)
- Data source type & version: N/A
- OS Grafana is installed on: docker image grafana/grafana:latest
- User OS & Browser: Chrome
- Grafana plugins: not releavnt
- Others:
Below is the logs of the error
logger=context userId=1 orgId=1 uname=admin t=2023-02-15T16:23:30.122333495Z level=error msg="Playlist not found" error="Playlist not found" traceID=
logger=context userId=1 orgId=1 uname=admin t=2023-02-15T16:23:30.123118776Z level=info msg="Request Completed" method=GET path=/api/playlists/1 status=404 remote_addr=10.10.100.1 time_ms=3 duration=3.6022ms size=46 referer=https://grafana.domain.org/playlists/play/1 handler=/api/playlists/:uid
logger=context userId=1 orgId=1 uname=admin t=2023-02-15T16:23:35.546556423Z level=error msg="Playlist not found" error="Playlist not found" traceID=
logger=context userId=1 orgId=1 uname=admin t=2023-02-15T16:23:35.546679607Z level=info msg="Request Completed" method=GET path=/api/playlists/1 status=404 remote_addr=10.10.100.1 time_ms=1 duration=1.648177ms size=46 referer=https://grafana.domain.org/playlists/edit/1 handler=/api/playlists/:uid
logger=context userId=1 orgId=1 uname=admin t=2023-02-15T16:23:37.884611113Z level=info msg="Request Completed" method=GET path=/api/live/ws status=-1 remote_addr=10.10.100.1 time_ms=9 duration=9.32184ms size=0 referer= handler=/api/live/ws
logger=context userId=1 orgId=1 uname=admin t=2023-02-15T16:23:42.716635229Z level=error msg="Playlist not found" error="Playlist not found" traceID=
logger=context userId=1 orgId=1 uname=admin t=2023-02-15T16:23:42.716766455Z level=info msg="Request Completed" method=DELETE path=/api/playlists/1 status=404 remote_addr=10.10.100.1 time_ms=0 duration=912.507µs size=46 referer=https://grafana.domain.org/playlists handler=/api/playlists/:uid
logger=context userId=1 orgId=1 uname=admin t=2023-02-15T16:23:46.815033446Z level=info msg="Request Completed" method=GET path=/api/live/ws status=-1 remote_addr=10.10.100.1 time_ms=1 duration=1.621784ms size=0 referer= handler=/api/live/ws
Chrome console gives me these errors:
fetch.js:32 GET https://grafana.rsu87.org/api/playlists/1 404
(anonymous) @ fetch.js:32
e._trySubscribe @ Observable.js:38
(anonymous) @ Observable.js:32
a @ errorContext.js:19
e.subscribe @ Observable.js:23
s @ mergeInternals.js:53
(anonymous) @ mergeMap.js:14
(anonymous) @ lift.js:10
(anonymous) @ Observable.js:27
(anonymous) @ share.js:60
(anonymous) @ filter.js:6
(anonymous) @ tap.js:15
y @ mergeInternals.js:19
g @ mergeInternals.js:14
s._next @ OperatorSubscriber.js:11
t.next @ Subscriber.js:34
(anonymous) @ innerFrom.js:51
(anonymous) @ catchError.js:9
(anonymous) @ takeUntil.js:8
(anonymous) @ throwIfEmpty.js:8
(anonymous) @ backend_srv.ts:99
(anonymous) @ Subscriber.js:123
t._next @ Subscriber.js:63
(anonymous) @ Subject.js:38
t.next @ Subject.js:30
(anonymous) @ ResponseQueue.ts:30
(anonymous) @ ResponseQueue.ts:35
(anonymous) @ FetchQueueWorker.ts:54
(anonymous) @ mergeInternals.js:25
(anonymous) @ FetchQueue.ts:76
(anonymous) @ FetchQueue.ts:55
(anonymous) @ FetchQueue.ts:59
(anonymous) @ backend_srv.ts:104
(anonymous) @ map.js:6
(anonymous) @ lastValueFrom.js:7
o @ lastValueFrom.js:4
request @ backend_srv.ts:79
get @ backend_srv.ts:391
start @ PlaylistSrv.ts:82
r @ PlaylistStartPage.tsx:8
rs @ react-dom.production.min.js:157
Wi @ react-dom.production.min.js:267
Sc @ react-dom.production.min.js:250
kc @ react-dom.production.min.js:250
wc @ react-dom.production.min.js:250
hc @ react-dom.production.min.js:243
(anonymous) @ react-dom.production.min.js:123
t.unstable_runWithPriority @ scheduler.production.min.js:18
Ho @ react-dom.production.min.js:122
Vo @ react-dom.production.min.js:123
Zo @ react-dom.production.min.js:122
lc @ react-dom.production.min.js:237
enqueueSetState @ react-dom.production.min.js:133
g.setState @ react.production.min.js:12
t @ index.js:205
(anonymous) @ index.js:215
Promise.then (async)
n._loadModule @ index.js:214
n.componentWillMount @ index.js:168
va @ react-dom.production.min.js:138
Bs @ react-dom.production.min.js:181
Wi @ react-dom.production.min.js:269
ze @ react-dom.production.min.js:292
$t @ react-dom.production.min.js:73
/playlists/play/1:1 Uncaught (in promise) {status: 404, statusText: '', data: {…}, config: {…}}
Docker latest image, grafana v 9.3.6
Trying to create and play playlists
Normal method
What happened?
Getting playlist not found error when I try to play, edit, or delete a playlist
Expect to play, edit, delete list after created.
No errors in UI besides Playlist not found
Chrome console gives these errors:
t @ index.js:205
I have downgraded to 8.5.16 and still the same issue.
Also, using the api gives me the same error:
curl --location --request DELETE 'https://grafana.domain.org/api/playlists/2' --header 'Authorization: Basic redacted'
result:
"message": "Playlist not found",
"traceID": ""
Turns out this was my fault. I had improperly mounted a docker volume.
