Looking for some guidance and direction to automate the configuration of grafana data source and dashboard when building a docker image with docker compose / dockerfiles.
I need to be able to add a Prometheus Data Source, and import a Dashboard that has been previously created using the dashboard editing tool.
- Create and Save Dashboard using Grafana UI
- Export Saved Dashboard
3.1 Build Docker Image
3.2 Create Admin User
3.3 Add Prometheus Data Source
3.4 Add / Upload Grafana Dashboard
Appreciate any guidance or direction.
Thanks,
