Using a panel variable in a complex select clause
Hi all,
I am pretty new to Grafana, and struggling to create a dashboard template. I have a “power” measurement with field keys that I don’t know in advance, and I want the user to be able to graph one or more of those fields on a graph.
I have created a dashboard query variable to allow the user to select the fields he wants to see:
$fkeys = query[ show field keys from "power" ]
Assuming the user has select “fridge” and “heater”, the graph query I am trying to create is this:
select mean(fridge) as fridge, mean(heater) as heater from power group by time(1m)
I have tried to create a second, hidden variable that would hold the
“mean(<$fkey>) as $fkey”
string for each select field key, but I didn’t go anywhere… is there any other way to achieve this?
Any suggestion welcome!
Thanks,
Franck
I just found this, which works acceptably though the labels end up as “mean_heater” and “mean_fridge”:
select mean(/^${fkeys:regex}$/) from power group by time(1m)
Franck
