Weird behaviour if screen width is below ~760px
    Grafana 9.5.2 as Docker container on Synology NAS
    Create a dashboard for mobile devices
    Place two elements side by side per row, so it’s a fit on mobile device with screen width of around 600px. So I expect the elements are shown on the mobile device with a width of around 300px each.
  • What happened?
    The default amount of 24 columns on a dashboard is reduced to one column, as soon as the display width is below around 760px. With that behaviour it’s impossible to place two or more elements side by side for a portrait screen like on a mobile device.
    The elements are side by side as drawn on the browser windows on a PC, which is of course way “wider” than the mobile resolution.
    Just put two elements side by side and reduce browser width below ~760px. Now you see what happens: Each element is using the full width, so it’s only one element per row.
    No errors at all.
    No, it’s just a dashboard with some simple elements.
No ideas so far on how to achieve this?
