World map panel and ElasticSearch raw document?
I’ve tried some stuff with the world map panel. The table format is working well with Mysql queries. However it seems that the ElasticSearch “raw document” queries are not possible or not regarded as table format? It seems that only the geo hash groping works. So even if I had coordinates in normal fields, there is no way to use them in as cooridinates in the world map?
Would this be the case?
