Zabbix Maintenance window show
I am new in Grafana. We are using Zabbix version 3.4 in production level. Currently I am exploring Grafana version 5.2 to more visualize for Zabbix user.
In zabbix, lots of normal users are claiming that they want to see the Zabbix maintenance window.
Is it possible to visible Zabbix maintenance window in Grafana ?
I have the same question.
Regards.
Hey @fredericarnould85 it’s really an old question that you’re bringing up from 2018… the only answer would be making a SQL datasource to pull the data from zabbix. If you want to try auto-translation from youtube you can try it here: https://www.youtube.com/watch?v=uzIpBPuNj9U&list=PLTAdaA8clXXK9A9rPjBKqxho4AGSTb6un&index=41
I’ll close this since it’s pretty old.
