Ability to color lines by threshold values
Hello
8.1 should be able to
The Time Series panel now includes the ability to color lines by threshold values.
is there a example where to set this exactly?
have a nice day
vinc
and on the playground
https://play.grafana.org/d/000000012/grafana-play-home?orgId=1
is 8.1 not added now. ;-(
do i miss something or its just hidden i can’t find it?
There does not appear to be anything on play.grafana.org reflecting v8.1 as of 10-August. Our Grafana Cloud version is also still running v8.0.6 as of 10-August.
You may be better off installing OSS 8.1 and playing around with it.
just would like to find out how to use it
Hello! Did you look at this topic: Graph and color schemes | Grafana Labs?
It has instructions on how to set the color by threshold. Hope this helps.
Just installed 8.1 and the instructions are clear.
Set gradient mode to Scheme
and set the color scheme to From thresholds (by value) then put in your thresholds, and voilla!
Hi…
is it possible to have the change of the colors more gradient?
I think you can add more threshold values.
@joekerna
You can choose Custom colors as well, but the default colors may give you what you desire.
