How to automatically set line color based on data?
Hey there,
I would like to set the plot color based on the data points. For example, if the very last point is greater than the very first point, set the color to red, otherwise make it green. Is this possible with Grafana?
Thanks!
Hi @vgoklani - check out the docs on setting Thresholds - this can be done with Stat, Gauge, Bar gauge, and Table panels. https://grafana.com/docs/grafana/latest/panels/thresholds/
