Grafana data point color based on value
  • What Grafana version and what operating system are you using? 8.5.0
    I am trying to color my points based on value , if value is 1 → Green, value is 2–> Blue, value is 3 → Red
  • How are you trying to achieve it? I have tried, thresholds, I have tried gradients but nothing so far has worked, is this possible with Grafana?
  • What happened? It colors all my points the same color based on min, max or last tab that I select when I setup thresholds
  • What did you expect to happen? N/A → trying to understand if this is even possible
  • Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. N/A
Welcome
Check this out, color by overrides
https://localhost:3000/t/color-the-bar-chart-by-condition/69292/2
so this is coloring three different series by three colors, however i want to color data in one series only
want to color red dots to different colors
the principle is the same you use override. Another way is
Standard options > Color scheme
Might that work for you?
