Admin role permissions described incorrectly
Grafana Docs (https://grafana.com/docs/permissions/organization_roles/) state that Admin within an organization can “Add & Edit organization users & teams”. However, the appropriate control (Add new user) is not available for the Org Admin. So, please correct this mistake in the documentation.
Are you sure the error is the documentation and isnt your mistake?
I changed my role to Admin and cannot find any possibility to add new users. What I’m doing wrong?
As a Grafana Admin, I go to Server Admin > Users and then click New user.
Configuration>Users >Invite
The new user will be added
Alas, I can’t find ‘Invite’ in the UI. We use " OAuth2 with Azure Active Directory" authorization.
BTW, what is the input parameter for allowed organizations in the config file?
