Grafana Alert system
Hi Team,
Is there any way if any service is getting down or utilization is high can we get any email alert. If yes then can anyone help how to configure it.
Regards,
Harshavardhan reddy S
Hi @harsha20896,
What you are describing sounds like a very common use case for Grafana. Can you provide more info? Do you have a query that returns data that you would like to alert on? If so, share it, and the datasource you’re using. Screenshots help a lot!
