How to define Y axis ticks interval
I am using Grafana 8.05 to plot some data from SQL Server data source.
I am using a Time Series Panel to plot Integer (bigint) data.
Is there a way to fix the Y axis interval between ticks (not only the max and min ranges)?
Thanks.
This is currently not possible, but you can follow up this discussion on this topic:
